BURGLAR said:No. Did you disconnect the battery before you pulled the dist.? I see that you stated you were working around the starter. If the battery was connected perhaps you shorted out a wire down there or inadvertantly blew a fuse. The motor should at least turn over. Check all your fuses and wiring down around the starter first and also the ground cable on the battery where it is grounded to the body.
Dave
