intake gaskets
ecoman
naugatuck ct
2000 triple black conv.
intake gaskets help
hello,i am new to this forum and have found it very helpfull. just purchased my fist corvette a 89 coupe a couple days ago it started missing on #3 cyl cheched compression ok checked vacucum only 14in also had oil leak at rear of engine anyways decided to replace the intake gaskets. after i bought the gasket set noticed the old gaskets had the rear coolant passages open and the new set have them restricted which are correct?
89 coupe
air foil
performance chiphttp://corvetteactioncenter.com/forums/attachment.php?attachmentid=4444&stc=1
excel coilhttp://corvetteactioncenter.com/forums/attachment.php?attachmentid=4445&stc=1
open air box
Welcome to the forum :w
Why don't you post some Pics if you can. Fact is, Throw the front and rear gaskets away for the intake. and use The Right Stuff gasket material instead. Approx. 3/8" bead. Do a search for intake replacement or instalation and you'll find all the info.
thanks for the repy.but i am refering to the rear coolant passages on the heads.the old gaskets had the passages wide open the new gaskets are closed except for a small hole about 1/8. which are the correct gaskets?
OK, I don't remember, but there was some recent discussion on this, within the last two mos. or so. I think in a post of rrubel or Mad-Mic I think. Try PMing Rich. I haven't seen him post recently.
I think the new gasket is fine.
My '89 has the rear coolant passage blocked. I believe the new ones you got are correct.
Where did you get the gaskets? The original ones on my 86 had the closed passages, but the only ones I could ever find, even listed as being for my car, had the open passages.
Unfortunately, I'm the wrong person to ask about this. I know they changed it at some point, but not when. For 86 with factory manifold, you need the blocked gaskets. That doesn't help you much, I know, but if you can find someone with the '89 shop manual, it should tell you under the installation procedure for the intake manifold (section 6A1, I think).
[RICHR]
thanks for the replies i spoke with a local vette mechanic yesterday he told me to use the restricted gaskets
