air1jpg
The interior door trim on my passanger side door is loose. I looked down between the door and trim peice and found several pieces of fiberglass that the door trim is supposed to hang on. Several of mine are broken off and someone replaced one with a L shaped peice of sheet metal. My question is that can the pieces of fiberglass that the door trim is supposed to hang on be replaced? I could not see if the fork shaped pieces of fiberglass are connected to something that can be replaced or am I looking at replacing half of or the whole the door? :confused
