- Thread starter
- #21
White75
- Joined
- Sep 21, 2007
- Messages
- 496
- Location
- Kingwood (Houston) TX
- Corvette
- '75 L48 Auto White, '78 L82 4-spd SA
Now that I got the seats together, I wanted to get them in place. However I still needed to get a few more things done before I did that. Tthat blasted seatbelt bolt needed to be removed and the rest of the B-pillar trim and rear window trim needed to be put back in place.
First the easy stuff, rear window and pillar trim. Start with the rear window frame, 5 screws hold that in place. Then the vertical B-pillar pieces. These slide into place and are held by 4 screws sandwiching a lip of the body's door opening between a piece of metal trim and the pillar. The shoulder locater for the seatbelt is next (don't forget the rubber cover over the webbing and finally a small screw near the front of the panel
Repeat for the other side:
Next, screw in the upper pillar panels.
and finally, the lower window trim bar
And that's all there is to that. And I badly need to clean out all the tools and debris that has collected all over the car.
