Just wondering if anyone has encountered the following problem in the past.
Details 1988 Vette
Standard Transmission 4 + 3
The clutch master cylinder was replaced with an aftermarket unit.
The line from the clutch master cylinder to the slave cylinder also replaced.
System was bled in accordance with maintenance manual.
Symptoms
Initial clutch pedal pressure observed as normal allowing full clutch disengagement.
Upon a subsequent engagement of the clutch, the pedal travel before pressure was encountered was approximately half way to the floor. As you can imagine the clutch in this case did not fully disengage.
The next clutch pedal action revealed full clutch pressure with little or no free play. Complete clutch disengagement achieved.
At first I thought that there was still some air in the system but after several attempts at bleeding the system the same results occur. Clutch pedal pressure is intermittent.
On occasion I am able to shift through all four gears without incident.
I am now thinking that the after market Clutch Master Cylinder has an internal problem with a seal possibly rolling internally.
WTS
Details 1988 Vette
Symptoms
WTS
