Jim Z06
Active member
It's time for a coolant change on my 02 Z06. I thought I would try it myself to save $100.00 Is it necessary to bleed the coolant system after the change? How would I know if there is air in the system? Thanks, Jim
Bringing this thread back to life since the problem I have is similar ... I think ...
Four months ago I had the local Chevy dealer completely flush the coolant system on my 2002 Vert. I've noticed that I have a problem that may or may not be related to that work.
The problem concerns the large return hose that runs from the water pump outlet to the radiator inlet on the upper left side of the radiator.
Almost every time the system totally cools down overnight, the next morning that hose is squeezed completely flat. When I start the car in the morning, the hose remains flat until the thermostat begins to open and then it fills out and remains normal in all respects until once again the system has cooled overnight.
On the first start of the day and all subsequent starts, the engine coolant and oil temperatures seem to come up to the normal operating range at the usual rate and stay within the normal range at all times.
I'm purely guessing there is trapped air in the system and that the resulting steam/air either isn't exiting out of the port on top of the radiator and then flowing to the surge tank or, alternatively, the steam/air is getting through the port and then isn't purging out of the radiator cap.
Anyway, this is my rudimentary guess as to what might be the problem(s). My knowledge of the cooling system is minimal and I'm not sure how to trouble shoot this problem correctly.
Any help would be greatly appreciated.
... But, after the system cools down I look into the surge tank reservoir and discover that the dealership overfilled it to the tune of 2 quarts when they flushed the system. I siphoned the excess out. Again, never trust anyone ... never trust anyone ... never trust anyone.
I'm betting this was the real problem. We'll find out tomorrow.
