L82Dan
- Joined
- Apr 30, 2002
- Messages
- 110
- Location
- schaumburg, IL, USA
- Corvette
- 1979 L82 Coupe dark brown metallic
That's correct. I believe it's on the tach gauge, under the crossed flags emblem.
Thought I'd add something to this list. There's a L-82 emblem on the face of the tach.Bizzy77 said:Several ways you can tell if you have an L-82 or not:
1. Check for hood ornaments; "L-82" on both sides.
2. L-82's have aluminum valve covers.
3. Emissions tuneup sticker above the brake booster should show an engine code
for L-82. (It won't say L-82!)
4. Speedometer redline is generally about 200-500 rpm higher than base engine;
it makes a difference whether or not you have an auto or manual.
5. VIN number, of course ! ! !
6. The engine block stamp will show an L-82-specific suffix after the number.
7. The cylinder heads on L-82's generally have larger valves than the base engine.
8. The camshaft is different. (Same as the LT-1 I think)
9. L-82 engines have a higher compression ratio than the base engines.
10. The Rochester carburetor part numbers are unique to L-82's; what you've got on the car dictates what the carburetor part number is.
Just my two cents worth...
The dealer may have done this, but I'm sure that it wasn't in error.frehan said:ok now I'm really confused. I just saw another 79 Vette on ebay with the L82 badges and the seller a dealership listing it as an L82 and the VIN says a L48. 8 is the fifth number. I called the previous owner of my vette and talked to him about the L82 badges and he said he was positive they are original. did chevy slap the badges on these vettes by mistake in 79? I wonder how many 79's have the badges but not 4 in the vin. check out ebay motors 1979 corvettes. it's white and listed 1979 L82.
Fred
frehan said:just to add the item number on that ebay vette is 2485133301. check it out. the vin says L48 but it has the L82 badges. this is strange. might have a more valuable vette than i originally thought if chevy did this in error.
Fred
p.s. wish i could post a pic of my vette but i can't seem to get it to work.
