richscorvettes
Mark,
I went into the barn to search for the two "Z" bars I have. I had looked at them before but wanted to refresh my memory. I have one original small block bar and a new one for a big block. As John said they are both 11" wide and I can't see any differences between them. Also, the clutch forks are the same. The only difference in setup I can see is that the clutch fork push rod is 9" long for the big block and, on the 64-66 small blocks, it was 10 & 1/2" long.
While I converted to a hydraulic setup and didn't install the mechanical linkage, I've been helping another friend with his 502 installation. He used the Scroggins-Dickey mounting plate, a stock bell housing and his stock small block "Z" bar. He said they did have to cut the bar in half, remove a small section, and reweld it because it was too wide. That's also what 67 Heaven had to do. He also said they had to do some minor grinding on the SD mounting plate. If I get any more information I will pass it along.
Rich Lagasse
Rich Lagasse
