Hib Halverson
Thanks Hib-you seem to be the go to guy on this site.
Some will say I have you fooled.:L
I'll try to get that wax.
I forgot to suggest taking a look at C-MagicWax.Com - Engineered to Shine
Also tell me about Red-line motor oil,like why do you use it?(snip)
Well....first let me say that I'll qualify my answer based on
1) I don't worry about the cost of the oil as it's a minor part of my overall "car budget".
2) I run my engines pretty hard sometimes and I do it in the desert southwest.
3) I, also, usually run my engine oils to extended drain intervals.
That said, I like Red Line because
1) It base stock is ester-based...the same base used for turbine engine oils and the best choice if the engine oil will be subjected to high oil temperature. Red Line's optimum oil temp is 225-250°F and it works well at up to 300°F. Also, that's temperature in the oil pan. The temps in bearings will, obviously, be higher. I'll admit that ester-based oils tend to be more expensive than Mobil 1, which uses a mix of synthesized hydrocarbons and highly-refined petroleum as its base, and many do not feel the extra cost is warranted.
2) I think Red Line's development and quality control are top notch. I have a friend who was formerly employed by Phillips Petroleum and before that the company which owned the 76 brand. He's a petrochemical engineer and he told me that Red Line was the finest of the boutique oil refiners, "boutique" meaning a small blender or refiner which produces a specialized product.
3) I've used the product since the early-90s and have a long-running program of spectrographic oil analysis of the oil I drain from my engines. They tell me Red Line is pretty good stuff. I, also, provide the data to Red Line for them to track how their oil is used in the real world. I have three engines in daily-driver use on this program. Two of them are high-mileage (over 100,000 miles). I also have three engines in Corvettes in this test program but none are high-mileage or daily drivers.
4) I know most of the owners of Red Line Synthetic Oil personally and their response to customer and market needs, devotion to quality in their products along with their support of motorsports, especially that portion of the support that goes to grass roots racers, have earned my respect.
