I just tried to install the correct pcv for my 66 327/300 in place of a threaded valve with no markings. The new valve is a 726c ac valve. the nipple pipe side on the new valve is open when the vacuum is applied(motor running, while the old valve closes with the motor running. I'm wondering if my system was even working with the old valve even though the motor seemed to run fine. the motor runs flat now with the new valve installed and the idle is about 200rpm higher. Is it a matter of readjusting the carb or is the new valve a problem? I put it back the way it was for now and it runs fine. thanks
