Bonnell
When I purchased my 2008 coupe last week it did not have the NPP exhaust on it. I asked to add it. They said no problem that they would order it.
Several people have made comments that adding NPP is not possible so this morning when I took it in I asked again and explained the issue. The service manager said that they had added many and it was no problem.
I want you to understand that the dealership has been very accomodating and very helpful.
I went to get the car just after lunch and I had a meeting that I had to run back to so when I noticed that I did not see any butterfly valves I asked about it and he did not one one way or the other if they should be there like on the Z06. I had to run back to work.
This afternoon on the way home it was apparent that nothing dramatic happens when I hit 3500 rpm. There seems to be what I assume some of you call drone at highway speeds.
The jury is still out. The original exhaust had a deep growl that I really liked. I am noth sure this sounds as good except at idle. It sounds way better at idle than the tame original.
I called when I got home and he was very patient as I explained the difference between the Z06 exhaust and the non-Z06 NPP exhaust. He could not find any other part numbers for the 2008 Corvette except the original and the GM performance exhaust that they put on today.
He is going to see what else he can find out but right now all I know is that I had a $1,625 exhaust installed and all I know is that it has bigger tips, is louder at idle and the GM part# is 19172324.
I have posted some pics below. If you can identify this exhaust and tell me anything about it I would apreciated it. It seems you guys know more about my car than the dealership does.
The imprint on the tip is the C6 Corvette flag with CCA underneath:
