I
igasper10
Ok... I just rebuilt and installed my original Q-Jet for my 74 L48. I got all my idle speeds set for their initial adjustment (1600 rpm fast idle, 600 rpm in drive curb idle with the screw NOT the solenoid). Its starts up great and runs ok but its only getting about 16 in. of vacuum. So I hooked up my timing light and the mark is jumping all over the place between 8 and 12 degrees! I had a Holley 4175 carb on the car while I was rebuilding the stock carb, and when I set it all up I had no problems. The timing mark was steady and I was getting 19-20 in. of vacuum. What's happened? What causes the timing mark to jump like that? Keep in mind I have moved to Colorado to an elevation of about 6000 ft. Would that have anything to do with it?
PLEASE HELP!!!
ian
PLEASE HELP!!!
ian
