Just fitted an Edelbrock Q Jet and Performer manifold!
  • Thread starter Thread starter AUSSIEVETTEMAN
A
AUSSIEVETTEMAN
Hi guys,
Just fitted an Edelbrock Q Jet carb (1903 795 CFM) to replace a Holley 650 spreadbore double pumper the previous owner put on.
BIGGGGG difference!
It started out by buying the carb from a guy in the US via Ebay. Got the carb for $330 US, which is a saving of around $110 or more. This is a big amount once it gets back to Australian Dollars.
I had my local carby bloke fit the carb, but he had a set back.
After removing the Holley, he accidently dropped a nut from the carb down into the inlet manifold! Bugger!
He called me to let me know and said that he will pay for anything he does to fix the problem.
After removing the inlet manifold, he noticed two things, one was that the water jackets on the original inlet were showing there age and the second was that there was no nut. :duh
The heads soon came off. There was an upside to that, they had never been off, that's right this was a virgin engine from 1981. I could hardly believe it myself as I thought for sure that it may have been rebuilt in that time. There was a build up of carbon at the top of each bore, valves were in pretty good order after 22 years. The original head gaskets were cactus, and that may have been a contributor to my heating problem.
New gaskets went on and so did an Edelbrock performer manifold inplace of the stock GM unit (the stock one will be repaired and stored). On went the carb and the adjustments were made to the kickdown cable.
All the 'block-offs' that were on the vacuum hoses were fitted back to the carb and everything looks sweet.
I drove her after everything was done and nearly fried the tyres first time.
The Holley was over fuelling the engine when you hit it and as a result, there was a BIG flatspot. The Edelbrock has no flatspot and it seems that we have at least 40% more power!
I know that that is not possible, but that is the way it seems.
Just touch it and BAM, there she goes!
I would highly recommend the carb to anyone planning on putting one on.
Cheers
Tony
same set up I have runs great now you need a curve kit for your distrubtor & a different chip then she will really smoke.
Clar2001
Clar2001,
I have a Mallory ignition system, Mallory distributor and Blaster 3 coil.
(Well I will have a new coil this week, the old one is starting to leak, so I ordered a new one)
The old HEI distributor is long gone, probably because of parts availability here in Oz.
Some people are afraid to look outside their own country for parts. Shame really, it just means that somewhere along the line a future owner (or caretaker) must spend a few dollars changing things back or improving a previous stuff up.
Cheers
Tony
Oh yeah the nut!
Les,
The nut was found behind the inlet valve, in the top of the head.
Lucky the guys carefully counted parts coming off and didn't start her up!
Things could have been a bit more expensive for them.
Nah, the did a bloody good job and at least they called to let me know what was going on.
Cheers
Tony
On the choke hot air tube that goes down into the intake I had to cut it down and weld it to about 1 1/2 inch. Did anyone else do this?
Not hooked up.
Weave,
We haven't hooked the choke up yet on my system.
After a couple of pumps and a crank, it idles by itself anyway.
We will hook it up at a later date.
Anyone else hooked up the choke?
Cheers
Tony
I found the hot air choke would only install with the intake off ,other wise you would half to mod to fit ,I switched mine out for a electric one haven't installed yeat the weather has been to hot to need a choke ,I found the air one not to work very well held hi idle to long.
Yep, we are not in a hurry to hook the choke up.
clar2001,
Yeah, all we do is start to crank the engine, give her three pumps on the gas and when she starts, hold her on around 800 rpm for about 15 seconds. She will idle after that, no probs.
Unlike the Holley, you gave her two pumps and after it backfired and spluttered and you could keep the revs to 1500 rpm, she was right.
Totally wrong carb for the car.
The Edelbrock is far superior to the Holley in my opinion and based on my proof of the difference the Edelbrock made after the installation.
Cheers
Tony
The Edelbrock Q-Jet 1903
Is a great carb performes well, I would not switch to a holly
I have had a Holley 650 on my 77 for 20 plus years and it sucked. I went back to a 1903 Q-Jet and as you say;" What a difference!" It made the motor come alive. Much more snap in the primarys and better top end performance.
Yeah Buckskin7t7v, it's alive!
It has made a very big difference to my car. She just came alive!
I have another little adjustment I made this weekend.
While fitting a HD 2-5/8" radiator, commonly found on earlier models, I replaced the air dam seals around the cold air induction system. This will, I hope, force more air into the carb creating more HP. Well, it is good in theory!
Cheers
Tony
Any brand well tuned and properly sized carb on a car will show no SOTP difference. My guess is that the Holley was either in need of a tuneup/cleaning or was completely setup wrong for your car.
I have the edel #1903 and have swapped out the hot air choke for an electric. I have it setup so that the choke starts choking at about 50F.
