Bonnell
Hi Everyone,
After 25 years I finally have another Vette (the first was a '73). I have just purchased a beautiful 1988 coupe and I have the following problem:
The car simply stopped idling properly and would stall. The computer was replaced and several things such as the A/C display and the A/C functionality were corrected along with the erratic idle.
The new problem is that the car now wants to idle at 500-550 RPM (it previously idles at 600-700RPM). The dealship technician says that this is the correct setting and the computer (is this the ECM?) adjusts to this RPM no matter what he does. The problem is that it will simply quit sometimes as I let off of the gas to brake to a stop - I can see it fall below 500 then it quits. It starts right back and away I go. The only solution is to keep one foot on the gas and the other on the brake when stopping. It does not always quit but I don't take chances.
The tech simply suggested that I use a can of injector cleaner (he can't get it to run any better) and give it a complete tune up.
I am a quick learner but I am NOT a mechanic.
I really need for this car to run as it is my 'driver'.
Any ideas???? Thanks in advance.
