S
Skant
I just got my K&N Filter from ZIP today. I tried to install it. I figured it would just be a replacement filter, right? Easy. Just take the old filter out and put the new one in.
Wrong.
For some reason, the K&N filter is not the same size as the OEM filter. So to make up for this, they have these silly little foam pieces you're supposed to try to arrange around the edges of the airbox to fill in the gaps.
The filter was also too wide. By about an eighth of an inch. No matter what I did, it would either stick out the left side or the right side of the airbox.
So overall by the time I had it all sandwiched together, I felt no confidence in this mickey mouse jury rig of a product making a seal and staying sealed over time. I just couldn't put something that silly into my precious vette. I took it out, put it back in its box, and will return it.
I can't understand why K&N doesn't just manufacture an OEM sized filter for the Corvette. Instead, they appear to be using some generic sized filter with a mickey mouse kit to try to make it fit even though it really doesn't.
I've used K&N before on other vehicles and it was great. Direct replacement. Easy. It's just the kit for the Corvette which is useless.
Plus it seems to be controversial whether the K&N filter produces more power in a vette anyway.
I got an open air box at the same time, and that seems to be just fine. Though I can't say I actually felt any power increase. Going to open air made a very noticable difference in my other vehicles, but I think the vette has a pretty good intake just to begin with. So the difference is much less.
- Skant
Wrong.
- Skant
