hsz33
1990 6 speed base corvette knocking sound at idle after warms up. the idle is not really rough just sounds like two metals hitting. its never consistant it comes and goes. Bad gas mileage, crankcase breather valve (passenger side valve cover) is missing so I just shoved the hose in it directly from the throttle body until I get one. ( it looks like the pcv valve on the driver side but its hallow!) which i replaced along with spark plugs. Also when gunning in 2nd 3rd I hear a wining sound from the passenger side under hood. At shut off I hear a rattle from under legs on driver side below the gas pedal. Its not the clutch or tranny for the noise does NOT go away when I press the clutch and it does not slip. could the crankcase breather valve missing cause a vac leak for the bad gas mileage and possible rough idle? Thank you, I hate to start replacing parts if not needed. No engine lights on.ad
