L88 Hood insulation
  • Thread starter Thread starter clar2001
C
clar2001
Just installed a L88 hood on my 75 does any one know where I can get insulation for this ?
ok one of those might work if I cut and paste it was hoping to find a stock insulation to fit the hood thanks for the links .......:)
L88s did not come with any insulation under the hood. Aftermarket will probably be your only source.
I really don't like insulation under the hood do I need to be concered about how hot the hood gets, on the out side it was quite hot to touch woulden't want to ruin any new paint when I get it painted or maby melt the hood
You could get a big sheet of aluminized insulation, and cut and crease it to fit. If you are careful, it would probably look a lot better than stock, and insulate much better, too.
Joe
Go Joe man did you open up the right door with aluminized insulation did a general search on the internet and cam up with the perfect solution in less than 5 min. here is there number 1-800-262-8099 car speciality shop attached is some info ,can cool wrap about any part of your car perfect for the corvette world.....
http://www.stockcarproducts.com/insulat2.htm
