F
farhaud
Hello all. How can I tell if a '68 Corvette is an L88 or other model? I looked around the block and can't seem to find any numbers.
http://www.corvetteactioncenter.com/specs/l88/l88engine.htmlhttp://www.corvetteactioncenter.com/specs/l88/index.htmlfarhaud said:Hello all. How can I tell if a '68 Corvette is an L88 or other model? I looked around the block and can't seem to find any numbers.
If it's not the original motor, it will be pretty tough to tell without documentation. Assuming it is the original motor, check the stamp pad on the right front of the block. Of course the VIN number should appear, as well as a date code with a two letter suffix. If it's a real '68 L88, the suffix should be 'IT'.farhaud said:Hello all. How can I tell if a '68 Corvette is an L88 or other model? I looked around the block and can't seem to find any numbers.
