Coupe de jour
I have a 91 coupe that I am planning to upgrade. I came across an intersting goody in the 2003 GMPP catalog. It is a 383 with 425 hp. It uses the 383 short block with the fast burn heads. Rather than go thru all the trouble of getting my stock L98 upgraded this sounds like a great option.
1. Does anyone know if the fast burn heads are compatible with the stock TPI base or the TPIS big mouth base?
2. Also, this engine has a lot of cam and I have to worry about smog since I live in California. How much cam can I get by with and still pass smog?
3. Is this engine compatible with the ZF-6 speed?
My ultimate goal is big torque. I live in an area with lots of great windy roads so accelerating out of turns is a kick. As a result I operate the car almost always in the midrange rpm. My plan was to mate the engine above with a TPIS big mouth base, non-siamese runners, and plenum as well as a complete exhaust with 3" cats. I was considering a cam with about 210 deg @ .050 and around .500 lift.
4. Can I go for more duration without killing the bottom end.
Thanks for the help,
Coupe de jour
Coupe de jour
