JonJon
Hey Gang
'86 Coupe L98/DN 4+3
The car sets an intermittent code 13 and trips the SES light. It only happens at cruise/light throttle at highway speeds and takes 8-10minutes to set.
Fuel pressure/volume are verified and base timing/min airflow are properly adjusted. Wiring/Vacuum lines have been checked/inspected and the left bank O2 sensor has been replaced. The FSM doesn't show a right bank O2 sensor and I can't find one.
What am I most likely missing?
Jonathan.....
BTW The DN unit won't shift into overdrive so I'm driving the car as a regular 4speed till I have time to pull the trans.
Jonathan.....
