corvette66
So I went and got a complete L98 intake unit today. It was from what they remebered to be an 88 camaro. So my first question is are they different from the ones in the vettes? I did notice that the intake manifold (bottom half) was a bit more rough and not so smooth looking as the one that was on my 86 vette. There was alos a few other things different.... the vette had a vacuum port with a gray metal tube bolted to it (on the driver side of the manifold between the two runners) this is not on the camaro intake. and it also has a plastic cover for the distributor. I thought the one on my vette was a pot metal material or some cheap metal.
Next, I want to put this on my 80 vette. So if i buy a 40-45 lb electric fuel pump for the firewall, will i be able to hook this right to the fuel rail? cause the TPI has a regulator.
Then what would be the best option for the return line? and can i block off the EGR on this intake?
And finally, do they make a nice wiring harness that i can just plug and play?
I have the computer but no harnesses. I really don't want to rip the wiring out of a camaro and try splicing it.
Im sure i will have a bunch more questions but this will get me started.
thanx guys for any help.
