B
billv
I bought a 90 6 speed convertible with headers, duals, and a GM HOT cam. The previous owner had a Crane cam w/ .575 lift and 240 dur., an LT1 intake with a custom chip. He then put in the current cam, and the TPI on with the chip for the old cam. He said all it would need is a new chip burned. I got a chip burned w/ all my specs, and it runs worse than with the other chip. It uses a Moates adapter. I put the stock Memcal back in, and it runs pretty well until it warms up, then it starts missing and popping through the exhaust.(It does this with all 3 chips) It is also running VERY rich, smoking. I set the timing to stock 6 deg., set the TPS, checked for vac. leaks, checked dist. Cap, etc. It has LT1 24lb injectors, and they check OK. Could the injectors be causing it to run bad in closed loop versus open if they were sticking or something? I’m running out of things to try. I’m thinking about putting the stock injectors back in and see if this helps. I know the fuel and spark aren't right, but it shouldn't do this. Anybody have any suggestions?
