L98 w/ HOT cam
B
billv
Is there anything other than a reprogrammed chip to run the GM HOT cam on an otherwise stock 90 L98? Can anyone recommend an inexpensive source for this?
www.fastchip.com will mail you a chip for $350 - just tell then what mods you have and send a check.
It should run with the stock chip. The idle will be high ... around 1000 - 1100 ... which will effect your power brakes, but it should run.
:pat
pcmsforless.com will make you a chip for $175 you wont be dissapointed with them.
Scott Hansen said he charges $44 plus shipping and will retune free.
