poorboys831
Hi there people-Ive got what seems to be a typical problem but the typical fix didn't work.My pass. side head lamp will go up half way but thats it .Replaced the nylon rollers but noticed that the gear shaft is sloppy when it's apart but seems fine when it's back together. replaced the gear same problem half way up ,moter seems to run fine but it will not raise the headlight past half way.It seems like the worm gear is coming away from the nylon gear or vice versa.Got any suggestions?-this is a 1993 lt1-thanks-I'm going out now to take out the assembly again and check out the reassembly
thanks Dennis
