Crosschkm
- Joined
- Jan 9, 2003
- Messages
- 83
- Location
- Chicagoland
- Corvette
- 93 ANV ZR1, 90 Callaway TT #19, 87 GN,06TrlBlzrSS
;helpI am having some fine tuning done and getting ready for the season. I have the car at Haibeck Automotive (
very competent shop) they specialize in ZR1's and work on a couple of Callaways. We were getting ready to increase :Jboost :Jand made some baseline observations prior to any increase and found this problem:W. The car is very solid other than this detonation problem.
The detonation occurs when I make WOT runs in third gear from 2000 to 5000 rpm. The ECM scan data shows the knocking beginning at 3000 rpm peaking at 3500 rpm and tapering off to sharply after 4500 rpm. 10 to
15 strong knocks occur with a peak retard of -12 degrees at 3500 rpm.
At the same time my wide band oxygen sensor records the following:
RPM 2000 2500 3000 3500 4000 4500 5000
AFR 13.0 13.3 13.6 14.9 13.8 13.3 12.1
Knocks 0 0 1 2 6 5 1 Total knocks for the run = 15
Boost is 52" hg. absolute.
Fuel pressure is 55 psi from 3000 to 5000 rpm.
The L98 fuel injectors were replaced with GM parts about 1000 miles ago. The electrical resistance is 17.5 +/- .1 ohm for the set hot.
The Callaway injectors are 2.3 ohms cold and 2.7 ohms hot which is said to be normal by Callaway technical support. They flow 83 lbs./hr. We cleaned them.
The electrical drive for the injectors is 12 to .5 volts at 10 ms.
We drained the fuel and filled the tank with Shell 93 octane.
The car does have the Callaway chip in it, but could it have been programed wrong from the start?
I wonder what the procedure is to add fuel to the Callaway Microfueler from 3000 to 4000 rpm?
We have contacted :BOWCallaway and they helped with a couple of issues, but they have not called us back reference this problem. I think they are busy, however does anyone else have an idea what could be causing this problem while I wait for a call back?
