Greg C
- Joined
- Jul 9, 2003
- Messages
- 102
- Location
- Ann Arbor Michigan
- Corvette
- 2000 Convertible;Bowling Green Metalic
I have a 2000 C5 Roadster with about 9000 miles on it (bought it 2 1/2 years ago with only 1234 miles on it).......anyway, took the car up to Mackinaw City, MI. for the annual Corvette Crossroads (I live in Ann Arbor, MI.), came home, parked it in the garage 4 days later pull;ed the car out to clean it and noticed a small puddle (about 3 inches in diameter) of trans axle fliud (almost clear looking) under the rear end. Put the car up on the lift today and it looks like it is slowly leaking from where the left axle shaft goes in to the trans/axle.
I called a friend of mine who works at the GM Proving grounds (he working on the C5 Project) and told me there have been problems with the axle shaft seal leaking. He thinks there is a fix, replacing the double lip seal with a triple lip seal, and also replacing the left trans/axle cover "o" ring with a new one and using lock tite on the cover flange..........has anyone else run into this? Am going to call the Chevy dealer and make an appointment to get the problem fixed and i just want to make sure I know what I am talking about when I do take it in........(the Vett has an extended warr. in it). Thanks.......
PS: guess so far I have been lucky with the C5, this is my first problem (not counting the colume lock recall)
