Left Tire Sensor Won't Read
  • Thread starter Thread starter Cessna 182
C
Cessna 182
My left front tire sensor won't read even after reprograming. I gess the sensor is bad. I have the magnesium wheels and am afraid of a tire shop damaging them to change the sensor. I have two questions 1. how do you tell if the tire sensor is bad. 2. where is the best place to get it changed, a dealer or tire shop
Jim
I had the same problem and finally fixed it be removing all the air from tire, then refilling it. The sensor came back to life and all was good. On a 99 your battery may be dead, on my 2000 it was not. We are both reaching, or have surpassed the end of life expectancy for the batteries. Good Luck.
Well Saturday I let all the air out of that tire and filled it back up and still no luck. I guess I need a new senser. thanks for the suggestion.
Cessna 182
I don't know where in KY you are but there are a couple tire shops near Bowling Green that will care for your rims. I had a sensor go out on my 02 and replaced it 2 weeks ago. I bought mine online from www.gmpartsdirect.com for $42 plus $10 shipping including the new nut to install it. It was $62 at the dealer without the nut. Your 99 takes a different sensor unless you have later wheels so you will need to figure out which one to buy.
