Left turn signal doesn't blink
Rocketkid
kirkland, wa
1981 Black
Left turn signal on my car stopped blinking, all three light (front, rear and side) come on but don't blink.
I replaced the flasher about 6 mo ago when both signals stopped blinking and that fixed it.
Is it possible that I have a bad turn signal switch?
sam
Check all the bulbs first, that is the most likely problem. If not it is a grounding problem; one of the light must not be grounded completely. Check the bulbs first that is the most common.
Gary
Do your hazard flashers flash the lights at all four corners? If they work and the left turn signals don't, it's most likely in your turn signal switch.
