Lights and horn acting freaky now...
  • Thread starter Thread starter vettegirl
V
vettegirl
yesterday when I left work it was raining hard, ran through several large puddles. Tried to turn on headlights, takes 4-5 tries before they finally flip over, and horn just makes a little "squeak" sound. What did I do to that poor car this time???
Lauren
Hi there,
If you really hit some deep ones, then you most likely submerged the light relay and the horns.
Horns are located under the right front headlamp assembly, and the relay box is under the left front headlamp assembly.
If you just remove the plastic panels where the bumper meets the lower panels, you can access both.
You will only need a 7mm to remove the panels.
They are black.
Allthebest, c4c5:hb
Thanks again...
I sent my husband up to the dealership with my "shopping list" this morning (I sure hope you guys aren't getting as sick of me and my car as he is!! :eek ). Anyway, the parts guy could not find a part# for the light relay - do you have this handy?
Also, from a previous post I wanted to replace the little 90-degree hose that comes off the PCV unloader - they said you had to buy the whole assemby for $ 95.00, and it was a special-order part. Does this sound correct to you?
Thank you once again for all your help, and I do apologize if I am becoming a giant pain in the :booty !
Have a great weekend!
Lauren
If didn't have bad luck, you wouldn't have any luck at all.
hang in there.
