Peer81
Hello,
Well I thought I didn't have a problem with my starter but I want to know what this little hickup was.
Last sunday I drove for about 2 houres (55F degrees outside) after parking for about 5 minutes I wanted to start the engine again. First thing only a click, second time also the click. After waiting for another 20 or 30 seconds the engine starter without a problem.
Now I already have a rebuild normal starter with 500km on it. No headers. Already cleaned and check the ground wires no problem there. I couldn't be heat because the 30 seconds wait didn't cool the starter. No low voltage because I have a new battery and a rebuild alternator, everything checked no problem there.
So I think something is causing the solenoid to click (I think?) but no start. As long as this is only the problem then I don't mind but I don't want this to grow any bigger.
That day I drove for about 460km with several stops normally more then 20 minutes and never had a problem. My friend with his '86 C4 has the same glitch so we want to know what to look for as it can't be anything big I think.
Thank you,
Greetings Peter
Thank you,
Greetings Peter
