jvette
New member
can any one tell me where the relay is located the problem i'm having is it automatic locks but will not unlock
Hi, Check the bulletins for your year on this web site.On my 88 Coupe, the power seats and door locks are on the same circuit breaker and their hot/powered all the time. The seat action back and forth abraids the power wire to them and trips the breaker, causing the door locks and the seats to malf. I'm not sure if your year is wired the same, I would look into though, I found the circuit breaker Red Hot and pulled it. The bulletin for my 88 clearly showed the problem and it was an easy fix. Just a thought Good Luckcan any one tell me where the relay is located the problem i'm having is it automatic locks but will not unlock
