Marv02
I put a set of SPL long tube headers on my 86 Vett.
the headers came with a 3 wire heated O2 sender I put the stock 1 wire O2 sender in I was not sure at the time which wire did what.
But now I know.
I just checking is the NON heated O2 sender causing my motor to surge at Idel it ok at first at a stop light or in stop and go trafic but after a minute or two it starts surging.
After you able to give it some gas the surge go's a way.
I been thinking the 1 wire O2 is getting cold that cause the surge due the sender now in the Header collector instead of next to the old stock Exhaust manifold.
Or what else would cause this it a new motor not stock it's a mild build I still working the bugs out the new build this is one of them.
But I getting there.
But now I know.
