Sensei
Okay, I need some ideas. I have not driven my car much for the last month or so because it has developed an extreme knock. It is very loud and solid, like it's about to throw a rod, but it only happens at very low RPMs. When it first starts, it will make this banging racket for about a second, but then it goes away and the car runs like a scalded dog as usual, no problems. I can make it make this horrible noise by lowering the idle to the point where it is on the verge of dying, and then it is banging away. I only did this because it was the only way I could think of to find the problem. But I have still not been able to locate the sourse. It seems equally loud from above and below. It does not seem to be anything external, like the fan hitting something, and seems to be more from the rear vs front of engine. I took the torque converter cover off and could see nothing hitting the flywheel. I used a mechanics stethescope on the block, heads intake, frame, starter, transmission bell housing and the torque converter cover, and could not hear it at all, strange! (although I could hear it plainly enough not through the stethescope).
The transmission is a BTO Level II TH700r4 with about 30k miles on it, well serviced. The engine is a modified L81 that was completely rebuilt about 40k miles ago and has also been extremely well serviced.
Could it possibly be the torque converter? I do not know much about the inner workings of these things. Would there be something inside one that could knock like that at low RPM, then function fine otherwise?
God bless, Sensei
God bless, Sensei
