low fuel warning light stays on
  • Thread starter Thread starter grpups
G
grpups
my low fuel warning light came on and after filling the tank full, the light still stayed on. has anyone had this problem before and if so, what is the fix? thanks....
Gas Gauge
Hi There,
I have had that problem as well but only at times, After putting more gas in everything returns to normal.C5s have a few issues that should be GM's problem as well as the consumer. Another one is scratched windows from something inside rubbing aganist something I'm sure. Which in my mind is a factory default. Anyone else had any problems with their windows? I priced replacement windows, $400.00 for the both, now fixing the problem that caused it in the first place is something differet.
I have a 1980 Corvette and have the same problem with the low fuel light staying on. While taking the center console apart, I found a small circuit board, looks broken with a light bulb in the center laying inside the consold not connected. Not sure what this is. May be related to the low fuel issue.
cool80
