CulverC4
- Joined
- Feb 7, 2008
- Messages
- 31
- Location
- Culver City, CA
- Corvette
- 1989 White Convertible w/ Black Top
Hey everyone,
I just started having an issue where my engine begins to idle rough as it warms up/sits idling. As soon as I come to a stoplight for example the idle will be fine at first but will begin to gradually roughen the longer I sit in gear, foot on brake. The interior dash lights and headlights will also begin to dim and the car will sometimes go down to 500 or so rpm. I also noticed that the car's in-dash oil pressure gauge will read as low as 9-10 PSI. The funny thing is when I start her up when cold the revs at idle will read around 700-900 rpm, oil pressure will read around 40 PSI, lights don't flicker and acceleration from stop seems stronger. Also, sometimes the flickering lights situation/weakened acceleration/rough idle will "magically" disappear for a while, then it will return if stopped in gear for too long. I recently had the intake manifold gasket, valve cover gaskets and fuel pressure regulator replaced. Also, the rotor was replaced as one of the pins broke off inside and the engine was misfiring for a couple hundred miles (one of the cylinders wasn't getting spark). A local corvette shop replaced the rotor and replaced 2 wires with AC Delco wires, but the rest are aftermarket wires, could this have something to do with it? Also, there is one vacuum line that is disconnected, it's near the accumulator. My old auto shop teacher from high school hooked up his real time scanner and we saw the coolant temp sensor spike on the graph, he said it might indicate a damaged CTS. A buddy had the same problem with his Denali (flickering lights) and a new battery fixed the problem. I think I replaced the battery about 1 1/2 to 2 years ago. Before I take it into the shop I'd like to be slightly prepared, any ideas guys?
Thanks in advance,
Jose
Thanks in advance,
Jose
