G
grapeknutz
Does any one have the info thats on the cam timing tag? I need it to research a engine combo.
Cool! I was hoping that is had the actual degree numbers in the IVO,IVC,EVO,EVC. Is which I am really after.Here is the info off a cam card for a "Hotcam" P/N: 24502586
Engine type ... SBC
Lifter type .... Hydraulic roller
RPM range ... 1500 - 5500
Engine family .... 1986 to present Gen1 and Gen2
Lobe lift ... Intake .328" Exhaust .328"
Gross valve lift I .525" E .525"
Lobe Centerline ... I 109 degrees E 1125 degrees
Duration @ .006" ... I 272 E 281
Duration @ .050" ... I 219 E 228
Rocker Ratio .... I 1.6 E 1.6
valve adjustment ... I zero lash E zero lash
Lobe Seperation ..... 112 degrees
Valve lift w/ 1.5 rocker ratio is .492"
Spring recomendation .... P/N: 12551483
OD .... 1.337"
Installed height .... 1.780"
Seat load .... 101 lbs
Solid Height .... 1.215"
