fastred87vette
i have never push it that hard yet since i own it only for the last 3k but tonight i when to the track with some friends and my 1992 auto 3.07 with 60k get straight out the box on D (not o/d) but just before shifting to second gear there is like a short misfire/cutting and once in 2nd everything o.k. till about 5000 rpm where the same misfire/cutting appear but worst and longer till getting to the 3rd gear after that she push it thru the 1/4 with no other issue and the car run as usual on the way back home... any idea on what can cause this problem ???injectors,fuel pump,optispark??? i did 14 1/4 miles run's and my best was 14.159 at 99.11 mph. with a 2.289 60 ft and a reaction time of 0.617 i run on 91 octane, the tank was 3/4 full, the outside temp was around 70, coolant temp between 210 and 230, A/C was off, ASR was off, tune up and gaz filter done, and the only mods are k&n, open air lid, air foil and muffler eliminator... i had a great night with the guys but i im sure this corvette can push harder on 1/4 than 14.1 at -/100 mph and i want to take care of this before it get worst... thanks in advance
