Here is a copy of my post on the same subject last Decmeber and Hibs reply, hope it helps:
Quote:
Originally Posted by
markone
Hi everyone:
This may have been asked before but I searched the forum and could not find a specific reference to a '92. Mine has 11k on it and I notice that there is a distinct "ticking" noise (if it was a pre '90's small block I would swear it was a lifter) after it is running for a while at oper temp. It appears to be less pronounced when cold. Is there a documented problem with noisy injectors on the '92's? I was planning on running some Marvel Mystery oil in with the regular oil to clean out the lifters. If anyone has any definitve information it would be appreciated.
Thanks,
markone
The key issue here is: how loud is this ticking?
We'll assume that it's not excessively loud.
It is normal that the ticking would get slightly louder when the engine is at operating temperature.
The 1992 LT1 has a slightly more aggressive camshaft profile than do 93-96 LT1s. The difference makes little or no difference from a performance standpoint but it does cause 92 LT1s to make a little more valve train noise so, with 92s, a little more valve train ticking or clicking is normal. The change in camshaft profile was made to reduce the loudness of this clicking.
Secondly, injectors, even when working correctly, emit a little clicking noise of their own.
Lastly, from about 94 on back, C4s have a noise problem with fuel-line-hammer, however, that noise is characteristicly different than valve train noise. If you have fuel-line-hammer, it sounds like someone flicking the top of a coffee can with their finger nail....kind of a thunk, thunk, thunk, rather than a tick or click. Fuel line hammer is not easiily eliminated.
DO NOT put "Marvel Mistery Oil" or "Justice Bros. Engine Tune-Up" or any other similar additive in your engine oil. They contain oil thinning solvents which should only be used as a last resort in a very-high-mileage engine with obvious levels of sludge and dirty oil. A 92 with 11,000 miles on it will not be in that condition. Anything that thins oil is the LAST additive you want to put in an engine which already has 5W30 oil.
The best thing you can do is switch from 5W30 synthetic oil to a 10W30 synthetic and learn to like the little bit of ticking your 92 LT1 valve train makes. Also know that your 92 makes about 3-5hp more than 93-96 because of the more aggressive camshaft.
Now....if this ticking clicking is very loud then we have a completely different thread.
__________________
Hib Halverson
Reply w/ Quote |
Quick Reply |
Report Post
