My LT4, with 96K miles, has an overheating problem that I can't figure out. The water pump was replaced about 25K miles ago and the heater and radiator hoses were replaced about 9K miles ago. Back in May the temps started fluctuating, up and down from 200 to the 230s. I replaced the thermostat with a 180 and everything was fine until a couple weeks ago. Now it's behaving in a similar manner, temps moving up and down, with a max of 240.
This morning I took the cap off and topped the antifreeze off to just below the filler cap. Started the engine, and when the temp reached somewhere around 140 the coolant started moving up and with some flowing into the overflow tank. The level moved up and down until somewhere in the 160-170 range, then it started bubbling out like crazy. Does this sound like a blockage somewhere? I suppose the thermostat could be bad already. Any ideas would be appreciated.
