LTPWS-module location
  • Thread starter Thread starter whsteele@bellsouth.net
W
I am getting a DTC code 99 thus the module is probably bad, can someone advise me where this module is located!!!!
I believe it's located behind the DIC. It's mounted vertically next to the chime/alarm module. It looks like you'll have to remove the upper trim panel to access it.
Don't know if you have the factory manual available so here is an excerpt from mine.
A DTC 99 will set if the receiver/control module does not receive
any wheel sensor signals for three consecutive thirty minute peri
ods with the ignition in the "On" position.
Check for damaged or missing sensors on all four wheels. If all
four are present & ok replace the receiver.
The DLC is located under the carpeted knee bolster on the drivers side of the interior. The connector is black and located to the right, i.e. closer to the console area vs the drivers door panel.
