Hib Halverson
Bob1320 said:Don't believe any of the BS about carbon buildup, or additives for your engine noise. It is PISTON SLAP and nothing but. I am a certified GM technician and competition engine builder (30+ years). The piston to wall tolerance is excessive. GM just doesn't want to pay for their mistakes.....![]()
I can only laugh.
:L
Someone who was a GM tech and built engines would cite the piston-to-bore clearance specification for a Gen 3 engine in a discussion like this. Also, if a "certified GM technician" you knew this was "piston slap," he/she would also have some case information to post on all the engines he/she has disassembled and found excessive piston clearance. Please click reply and post that data.
C4C5 Specialist is correct and states the various causes of the noises.
Further, the noise--as long as it disappears when the coolant and oil approach operating temperaures is merely an annoyance and not a defect...at least not a defect in that it affects reliability or durability. There is no evidence to date that cold piston knock (if that's really the issue in the case that began the thread) in Gen 3s is a durability problem.
Anyone can say they are a retired mechanic and all Gen 3s with cold piston knock are defective. It's another thing to actually be a mechanic and have credible information proving the statement.
The position that cold piston knock is a defect will have some crebility with you whiners, here, can actually provide some evidence more than hearing some noise you don't like. Until then, your comments are really just useless static intended more to get attention and/or vent anger than be valuable information.
;worship
