V
vietvet
confused:confusedon an E4ME carb, if i have 11.6 volts at the wire to the m/c solenoid, can i assume the solenoid is bad if it is not cycleing????????? vietvet
i did what you suggested and it will click one time and then nothing. it will click each time i touch the terminals but not a continueoes cycle. is the ecm bad????????? vietvet
from what I've read it seems the connector is backwards on some vettes.What was the outcome? I'm now having the same problem.:confused
