M
mdsbch
I got my 85 Vette about a month ago, and it ran great for a few days, then it started cutting out intermittently (mostly when giving it gas at idle). It idles Ok until you push the gas pedal. It is giving codes 32 and 33. After researching several articles in this web site (http://corvetteactioncenter.com), I’ve decided to replace the two MAF relays. I called AutoZone and Murrays Auto parts, and both of them said they didn’t have any listing of the part. One of them suggested using the fuel pump relay as a substitute. Can this be done or are they different relays? If they are different, does anyone know what the part number would be and where I can get these relays? Also, after studying my Chiltons Repair manual, fig 70 on page 4-24 shows the Vin 8 engine electrical diagram for the MAF (I am assuming this is the one my 85 has) and it shows both the MAF Sensor Burn-off relay and the MAF Power relay. However, when I look at fig 91 on page 4-31, it doesn’t show the location of these relays for the 85 Vette. I looked behind the battery where it seems they are on later models, but there are none on my 85. I did find two relays in the general area, one in front of the battery on the inside of the wheel well and the other between the battery and the engine on the fire wall. Are these the MAF relays? Thanks for any help with locating these relays both in the Vette and at an Auto store.
Mike
Mike
