8
88canadianvette
is it worth the effort? and if it is what could the benefit be?
wookiebear said:I removed my factory MAF and replaced it with the Granetelli MAF,which does not have any screens at all in them. the gain is very minimal at best, but again every little bit helps. Its not a big job, just be careful that you do not cut the electronic element thats on the inside. I would not be concerned with any debris getting by, just make sure that you have a real good air cleaner preferrably a K&N, with doing both at the same time you will notice a difference in response and acceleration, while you have that apart you should also do the throttle body bypass mod that will add a tiny bit more and before you know it you picked up 10 to 15 honest RWHP! Then its AFR Heads, 3.73 rear, shift kit etc. etc.etc, etc, and you hooked for life! LOL!!!
l98vette1986 said:The aftermarket MAF is a little on the high side for me, so i cut my screens, and sawwed out my 7 aluminumn heat sinks, i wasnt satisfied so i used my mighty Dremel grinder, and honed out the whole thing. Personally i think that this should be done as more air=more power.
psy·cho·so·mat·ic (si´ko-so-matik) adjective
- Of or relating to a disorder having physical symptoms but originating from mental or emotional causes.
- Relating to or concerned with the influence of the mind on the body, especially with respect to disease: psychosomatic medicine.
— psy´cho·so·mati·cal·ly adverb
Ken said:...but when I pulled some dyno runs the other day we removed the MAF (I've still got it in place until I find new ductwork for the intake) and the accordion-pleat ducting for one run; the throttle body was open directly to the outside air. Also, the MAF I had in place is the hogged-out one with no screens or fins.
The runs we pulled with the MAF off were no different than the ones pulled with the MAF and ductwork in place. It could be that mine hasn't had all of the bugs worked out yet, or it could mean that the difference (with or without the MAF) isn't that noticeable. Just like the "air foil" insert for the throttle body basically being a waste of time and money.
_ken![]()
/B]
rrubel said:Ken, what is your car using to measure airflow instead of a MAF?
[RICHR]
Ken said:Jeff, what did you use to fill the gap? Is that a piece of PVC pipe? I was told places like Home Depot have rubber ducting that might be a way to go, I'm gonna check in on it one of these days. HD is not one of my favorite places to visit.
_ken![]()
