manual tranmission questions
  • Thread starter Thread starter acman60
A
acman60
manual tranmission
I have a 1979 vette.
EDIT: See Post #2. Merged duplicate threads. _XLR8 - Moderator
I have a 1979 vette and it has a 350 turbo automatic transmission.I would like to put a manual transmission in.Need to know what parts i will need to install transmission,and if is a pain putting in.THANK MARK S
acman60, I merged your duplicate threads into one to prevent confusion.
Good luck with your Vette!
:wJane Ann
You're going to need a pedal setup, clutch linkage, bell housing, tranny, check your block to see if there is a tapped hole for the linkage, should be but not all blocks have it.
Are you going for a complete 5 spd kit?
Your diff probably has 308 gears with the base setup you have. Check on the gearing of the tranny you want to use.
Kiesler makes a automatic-to-manual transmission conversion kit. Supposedly, it has everything needed to do the switch over - including the console faceplate.
Check it out: http://www.keislerauto.com/gm/corvette-c3-kits.html
Good luck with your project.
Ralph
