People will do cheap and easy fixes if they even get a hint that they can get away with it. Why do you think that they sell the battery operated supercharger or the Tornado?
Which one calls it the IAT (Intake Air Temp) sensor?
Shouldn't it set that code only if it falls outside the parameters? Not sure what the window is though.
I know that ford and mazda use the acroynm IAT, and I believe that GM switched to that terminology once the OBDII stuff began.
Codes 23-25 window/s parameters
code 23: is set when mat signal voltage temp. stays below -30c for 1 second, engine run time 2 min. and no vss signal,
or,
ignition on, engine not running, coolant greater than 60c, but mat signal voltage showing manifold temp below -30c.
code 25: run time 2 min. (or more), no vss, car not moving, and mat signal voltage showing a temp greater than 150 c.
or,
and vss signal present with greater than 5 mph., and mat voltage indicating a temp greater than 150 c.
Correct, it will be set when outside the above window/s. We and or the poster would not know this without either a scan or checking for codes at the very least. I agree with, and prefer with using a scan device of somesort, as it is easier than looking sensors over with an ohm meter and one can see it under operation (which in the case of an 02 is really the on;y way to understand if it is functioning properly). I have an auto x but on these cars I prefer the laptop with datamaster, tuner pro, or hp tuner etc. depending on the version/year of the car.
