Bill75, Koop, Chuck, I think someone was either pulling your leg or just confused. Your clocks...mechanical, quartz, or otherwise (save digital)...all work on the same principal as the mechanical watch on your wrist. Have you
ever heard that constantly adjusting the current time your wristwatch would make it more accurate?
Yeah, more accurate for the minute that you are adjusting to. But it doesn't adjust the actual mechanicals that keep time.
The only way to adjust for accuracy (that I'm aware of) is behind the scenes. On a wristwatch, that's by having a jeweler adjust the internals. Same goes with the clocks in the car, except that they
may have an adjustment lever or something on the back. I'm not familiar with that method, but someone else had mentioned that adjustment might be there. I don't recall seeing one on my clock, but I didn't inspect it all that closely.
But in short, adjusting the clock from the regular front access needle
I don't believe actually adjusts the internal accuracy +/-. It simply sets the current time just like it does on a mechanical wristwatch.
