HI there,
You both might have a problem with the soft stop position.
If the battery has been disconnected, you may have to relearn the positioning.
Simply go in every direction to the end and hold the switch in that position for 3 seconds.
Once that is done, reset your memory settings.
If its only in your seat, thats most likely the condition.
Allthebest, c4c5
