Ok guys [this includes you gals out there as well]! I am going crazy or something :W , but I cannot recall how far back (or into the cam cover seal) the harmonic balancer should be installed.:cry
Could someone measure the distance between the forward-most tip on the timing tab (I think the tip on the timing tab that is closest to the 0 degree mark) and the front edge of the balancer?
Honestly, I recognize that this request may not be easy to grant (given the small amount of room available), but I looked through the maintenance manual and it just says to install it. But, the sealing surface of the balancer that inserts into the cam cover seal shows about 1/4" to 3/8" space and the forward-most tip of the timing tab and the front edge of the balancer is about 0.43" or a little more that 3/8".
This could affect the alignment of the drive belts. So please answer my call for help. By the way, I have all the pulleys for an automatic L81 with A/C. Thanks a million, folks!
GerryLP:cool
GerryLP:cool
