PTighe
My amp gauge was working OK until I took off the horn relay from the radiator support and let it hang loose. I forgot to disconnect the battery and as luck would have it, the hot wire on the relay touched a grounded piece of the engine and it popped and sparked like hell.
No visible damage or smoke, but when I started the engine, the amp gauge pegged out on the 40+ side indicating something was wrong. Now it quit working altogether, it stays at zero, won't charge or discharge. Everything else works fine, did I cook the amp gauge and has anyone ever cooked one before?
